Hi all,
Having some trouble with my long time setup having switched from a Pi  3 to Pi 4. I've configured the software as:
- Raspbian Buster 2019-07-10 (with a post install dist-upgrade to kernel and Pi firmware)
- TheSkyX (Build 12281 - Latest Daily Build)
- ZWO X2 Driver 2.7
My hardware is:
- ASI 1600MM main camera
- ASI 174MM mini autoguider
The 1600 is connected directly to the Pi (with DC power plugged in as well) and the 174MM is connected to the USB hub on the main camera
TSX segment faults when I try to connect to the 174 specifically. The 1600 works fine by itself. I have tried connecting the camera directly to the Pi, through a powered hub, and though the main camera hub with identical results.
