I just got my ASI294 Pro and have some mixed results. I took some 3 minute subs and darks and flats and they came out very well. My 5 minute subs had some strange problems. The 5 min subs look good out of the camera and did fine with flats but when I added the darks they were messed up. I have some pics below to show this. I am a Mac user with Nebulosity 4.3. I did the 3 min subs at an offset of 10 and the 5 min subs at an offset of 8. I tried 8 at first but decided to go to 10. On the Mac it appears as if you have to set offset in Nebulosity. I used Craig Starks method to determine offset and decided on 10 but my first set was 8. I am setting gain at 120 for everything. My 3 min subs darks were the same gain and the offset of 10 and for the problem 5 min subs I did the darks at 8. I am assuming darks and lights have to agree on offset, temp and gain. All were done a -10C. A separate problem happened with a batch of subs taken that show the same problems with the subs themselves, not just when calibrated with the darks. I have attached pictures of each issue. I am trying to determine what is going on here.
All were debayered, stretched and auto color corrected in Nebulosity.
ASI294 3m well calibrated small.jpgASI294 5m poorly calibrated small.jpgASI294 3m sub not calibrated with darks or flats small.jpg
