Hi
the following steps may help you
1. Switch your computer over to the PMC-Eight-xxxx SSID specific to your controller. 2. Using Putty, TELNET into address 192.168.47.1 port 54372.
3. Enter "ESX!" on the terminal window and you should see an "ESX0!" response which indicates that the communications interface was switched to the serial port (interface 0).
4. You should now be able to use the SERIAL mini-USB Type B (female) connection with your mini-USB Type B (male) to USB Type A (male) cable to communicate with the iEXOS 100.
