I found some issues after i upgrade asiair app to 1.2.1 and, consequentely, asiair firmware.
1) it takes several tentative to connect android app to asiair. Always same issue. Even if asiair wifi Is visible from my asiair app, and my phone Is connected to It, it's impossible ti star the asiair app the error Is Always the same: no asiair detected. Unplug Powerline from asiair, star again to connect but It doesn't work. I Need to make this procedure at least 10 tentative to finally connect app and asiair. I Always noted that led read/write for the Memory card start to flash Red/Yellow at the beginning then It stops to red
2) debayer Button in the right column Is not present anymore. If camera acquires image, they are Always black and White. initially i thought It was my mistake. But today i Discovered that debayer Button it's not present anymore (Just below histogram button ). What was wrong??? It's a bug or my firmware it's corrupted ? Are the issue mentioned linked One each othet? How can i solve them?
