Hello. I have an ASIAIR (latest firmware) and an iOptron SkyGuider Pro with an ASI120MM-S guide camera attached to a ZWO Mini Guide Scope. I have the ASI120MM-S plugged into the USB port of the ASIAIR and the ST-4 cable connected from the ASI120MM-S to the ST-4 port on the iOptron SkyGuider Pro. Everything basically works and I “think” the SkyGuider is guiding because the tracking light blinks steadily when the ASIAIR starts guiding. Everything else works the same as it does on my Celestron AVX mount. I see the guide star and it locks on.
However, the SkyGuider only has an RA motor – no DEC motor – so the guiding program won’t settle down or it will time out waiting for the guider to settle. If it does settle down I’m getting VERY high RMS errors – hundred of arcseconds. So, my questions are:
What mount should I choose in the mount setup screen? I’m using “On-Camera-ST4” right now, since there’s no SkyGuider Pro option.
What settings should I use in the guiding setup? I haven’t changed anything from the default.
Should I turn DEC mode to off?
I have the focal length of the guide camera set to 55mm. Is that correct for an ASI120MM-S attached to a Mini Guide Scope?
Thank you very much for your help. I love the products so far and I just bought an ASI294MC Pro for my larger telescope!
