dear
I need help, my stargo is not recognized by asiair. (mount M-zero)
message : connect failed
I connect directly asiair to stargo using usb to usb because there're not rs232 port on stargo
speed 9600 baud, i try other, same problem
i try with lx200 protocol same problem
asiair v1.2.1 firmware 2.64
i've read that the connection on Indi is only with usb-usb cable, if asiair use indy librairy, it should be same ?
https://www.indilib.org/devices/mounts/avalon.html
best regard, 谢谢
Emmanuel
