Over the last several months my ASI1600mm C camera has not been able to maintain consistence temperature.
I tested the camera on my table in house using only my laptop and 12 v battery.
Example: Using Sharpcap I set the cooling temp to -20 degrees. The censor temperature will reach approximately -18 degrees, the cooler power will reach 100. Then the Temperature will gradually increase. The temperature will not maintain at or near -20 degrees.
I have downloaded the current software to run the ZWO camera, Also, monitoring the VDC to 12VDC.
I tried setting the cooling temperature to -15 degrees and censor temperature will reach -15 degrees with cooler power of approx. 74. The sensor temperature will remain near -15 degrees and the cooler power will gradually increase to 100 after 15 minutes. When the cooler power reaches 100 the sensor temperature will start decreasing.
Do you have any suggestions why the temperature won't maintain at the se temperature?
Thanks
Richard
