Hi Sir,
This is the description quoted in ASICAP help ducoment.
"Bin usually has four options: Bin1, Bin2, Bin3, and Bin4. The number after Bin indicates that several pixels are combined into one pixel. For example, Bin2 indicates that 4 pixels are combined into one pixel (2*2=4). Bin3 means that 9 pixels are combined into one pixel (3*3=9), and Bin1 means no pixel combination. Note: Under the Binning mode, as binning is increased, the resolution is decreasedbutfieldofviewremainsthesame."
Hope this could help you.
And if the camera is oversampled, then you can use bin to adjust the image.
