Hi Michel
i have tested on starbook ten,i think the method of starbook is same with it
here is the simple instruction
1.Starbook Ten and ASIAIR should join to the same network(use the router)
2.Starbook Ten->Settings,find IP 192.168.31.64
3.ASIAIR->mount->starbook Ten, type in IP: 192.168.31.64. (you can get
>it from the HC) Port:80 (fixed value)
4.Enter the IP address you got from the Vixen Star Book Ten to ASIAIR.
