Hi,
I have been using Astrophotography Tool v3.70 to control my ASI1600MM Pro. Recently, I have been getting download errors where APT is unable to successfully download an image form the camera. I may image for hours before the error occurs. Everything may work for for a day or two and then the download error will occur at random during an imaging session. Once the error occurs, no new images can be downloaded. However, if I simply unplug the USB3 cable at the camera and plug it back in, everything works fine.
I don't know if this is a camera issue or a cable issue or a ? issue. Have you or other users encountered this problem? If I'm not mistaken, it occurs with short exposures (25 sec) with a 5-sec delay between exposures.
Thanks for any insight you may have
Jay
