Skies are suffiently clear to do some guiding tests with ASIAIR v1.3 Beta (Firmware 3.16) using a 9.7" iPad Pro running iOS 12.4.
In spite of the hijacking of the "Speed 2" mount speed in the Hubo-i hand controller, auto guiding does work (hallelujah!), so this is an improvement over the release version v1.2.1 with firmware 2.64, which cannot auto guide the RainbowAstro RST-135 mount.
Here is the comparison of the 5 most recent ASIAIR releases ("proper guide speed" means the four RainbowAstro speeds are not altered by ASIAIR):
App version ..... Firmware version ..... Proper guide speeds ..... Auto guide Calibration
ASIAIR 1.1 .......... 2.28 ..... Crashes with RainbowAstro mounts
ASIAIR 1.2 .......... 2.61 ..... Yes .....Works
ASIAIR 1.2.1 Beta ..... 2.61..... Yes ..... Works
ASIAIR 1.2.1.......... 2.64 ..... No ..... Fails
ASIAIR 1.3 Beta ..... 3.16 ..... No ..... Works
ASIAIR 1.2 with Firmware 2.61 is still the best release so far for the RainbowAstro mount.
ASIAIR 1.3 seems to work as long as you can tolerate ASIAIR changing Speed 2 in the hand controller behind your back.
v1.3 Beta has new GOTO functionality (which has moved from the Telescope Settings window to a popup in the Home window). I have not tried a goto a planet, nor the iterative goto yet. It is definitely more logical to move the goto interface to the same window that plate solve is performed, but the Preview wondow is sure getting more cluttered :-).
My current workaround for the hijacking of the hand controller guide speed is to settle for 128x as Speed 2 ("Find" speed, which I used to set to 100x) *and* set the ASIAIR speed slider to 128x before I power down the ASIAIR app. This way I end up with 0.5x for Guide, 10x for Center, 128x for Find and 1500x for Max when I am manually controlling the mount after using ASIAIR.
I have not yet tried Polar Alignment on v1.3 Beta, but ASIAIR PA has never been a problem with the RST-135.
