Hi,
Using fire capture with failing ASI120MC that was giving black / blank screen, now found time to take it down from the pole it was on and connect directly with short USB cable to MAC OSX, started latest version of Firecapture and I get the following error, freezing screens and flickering, is this hardware failure?
Camera model: ZWO ASI120MC
Camera vendor: ZWO Optical
Color: true
Pixel size: 3.75
Logging ASICam Exposure values:
Max width/height: 1280/960
Max bin: 2
Exposure -> min: 1000 current: 33000 max: 10000
Logging ASICam Gain values:
Gain -> min: 0 current: 50 max: 100
Logging ASICam Gamma values:
Gamma -> min: 1 current: 50 max: 100
Logging ASICam additional controls:
AutoExposure -> min: 0 current: 0 max: 0
AutoGain -> min: 0 current: 0 max: 0
Brightness -> min: 0 current: 0 max: 20
WRed -> min: 1 current: 52 max: 100
WBlue -> min: 1 current: 95 max: 100
USBTraffic -> min: 40 current: 80 max: 100
HighSpeed -> min: 0 current: 0 max: 1
SoftwareGain -> min: 0 current: 0 max: 0
AutoHisto -> min: 0 current: 0 max: 0
FPS -> min: 1 current: 100 max: 1000
e/ADU: 3.712
Aug 26, 2019 6 PM de.wonderplanets.firecam.ASICam setROI
INFO: ROI set to (0,0,1280,960)
Aug 26, 2019 6 PM de.wonderplanets.firecapture.log.Log logInfo
INFO: PixelSize: 3.75
INFO: Done: Checking cams...
INFO: starting
INFO: loaded library Debayer_x64.dylib
Aug 26, 2019 6 PM de.wonderplanets.firecam.AbstractFireCam setTimebasePrim
INFO: Timebase set to: T1
INFO: loaded library ImageUtil_x64.dylib
INFO: Native: Allocating image buffer
INFO: Native: buffer size: 1228800
INFO: Native: starting acquisition
INFO: Native: image capture failed with code: 11
Aug 26, 2019 6 PM de.wonderplanets.firecapture.log.Log logError
SEVERE: Image capture failed:
