Hi,
Is there a way to recalibrate the end points of the focuser, because I could only do it once in the Ascom driver. I have asked this question previously but there was no reaction,
Clear skies,
Janos
Yes you can reset the maximum steps.(end points)
Thanks for your reply ! Please explain where is that option, I don't see any option to reset the endpoints in the ASCOM driver.
Please see the attached photo.
Thank You,
I know that screen. The point is that I would like to adjust the zero position of the focuser, not the maximum range. I don't see an option how to do that.
Hi Sir/Madam,
OK, do not worry, that would be easy.
You can move the EAF to the position where you want to set as the zero position, and then click set as zero position, then done.:)
Thank you !
My pleasure.:)
