Hello, I talked to Wayne at Starlight Instruments and this is response. Please advise. Thank you
Jim if there hub/control box will control a bi-polar motor then my HSM motor SHOULD work. My HSM motors use a standard Ethernet cable. If their controller will only control a uni-polar motor, my MSM motor SHOULD work as it is a uni-polar motor and uses a 6 pin cable.
