Hi Paul,
As we know, for a 14 bit camera, it means we use 14 "0" or "1" to save a data. So the range should be 2^14=16384.
then the minimum is 14 "0"s(=0). and the maximum is 14 "1"s(=16383). it means we could use it to standard from 0 to 16383 . The maximum value is Not 16384.
And sometimes, for some camera, when there is a continuous transmission of 1, there will be other meanings. So it is not used as valid data. For 178 , it is an example. That is why the max value is 16382.
And as we know, for our 16bit, we add 2 "0" at the end of the data. It means that we multiply the raw data from sensor by 4. So 16382*4=65528.
Hope you can understand.
Thanks
Chad
