Hello,
Can you use the iPad air with the ASIAIR unit? I don't see why you couldn't, but its not listed in your list of supported iPads
Please let me know if this model iPad will work with the ASIAIR
Also, is there any way to adjust white balance manually or does the ASIAIR only have an auto white balance option?
Regards,
Skyhunter1
Hi
“Can you use the iPad air with the ASIAIR unit?“
Certainly,ipad air can works well with Asiair
“”does the ASIAIR only have an auto white balance option“”
Yes,This is currently the case
you can have a try on Asicap to adjust white balance manually
