Hi, Can I make a suggestion that you default the ASIAir to WiFi 2.4G?
I understand that 5G is better in many circumstances, however not all tablets/phones support this. So as my device didn't support 5G, I was not able to communicate with the ASIair to change the connection to 2.4G, in effect I couldn't use it. I had to borrow another 5G device to connect then change to 2.4G, but until I did had no idea if the ASIair was working or dead.
If the default was set to 2.4G, all devices could connect and then change to 5G if that was possible with your device. Seems sensible to me and would allow more people to use this... What do you think?
