Hello I am not able to make a Skysafari 6 plus Wi-Fi connection via the ZWO ASIAIR the telescope is skywatcher Explorer 200/1000 mounting Goto EQ-5 pro.
Hi
please make sure the mount connect to Asiair firstly
then try to connect the SkySafari
in SkySafari communication settings,choose connect wifi
and the ip address input:10.0.0.1 , the port number input:4030
Hello yes all this already tested even with different versions of telescopes works asiair only skysafari does not work
