>> can you tell me if the draw on my power supply will be 12 volts and that is converted to 5v for the AIR, or if the draw will be just 5v.
You will be connecting the ZWO 12V-5V adapter to the 12V outlet of your power tank. The 5V (USB Type A) output from the ZWO adapter goes to the power connector (micro-USB) of the Raspberry Pi.
The current draw from your 12V power tank will be the current draw of the Raspberry Pi multiplied by 5, divided by 12, and divided by the efficiency of the buck converter.
E.g., if the buck converter has an efficiency of 80%, then the current draw from your power tank's 12V outlet would be I*5/(12*0.8) Amps, when the current draw of the Raspberry Pi is I Amps. Multiply that by the number of hours, and that will give the Ampre-hour (A-hr) at 12V.
I just measured the ASIAIR current draw from the 12V connector of the ZWO 12V-5V adapter, when connected to a power supply that sources 13.7V.
When booting, the current spiked up over 0.4A. Actual peaks are probably quite a bit over that, since I am reading from an averaging meter.
When connected through 5 GHz WiFi, with ASI071MC-Pro (cooler not connected), but nothing active, the "12V" draw is about 0.33A . While downloading an image, the current again spiked up to a little over 0.4A.
The cooler of the camera that you are using is likely to pull more current that the current draw from the ASIAIR. I did not check focusing or guiding, but expect current draw to be a bit higher too when those are active.
Don't worry about not being an EE. I am an EE, but well past my sell-by date, at over 70 years old :-).
