Setup:
ASIAir
Mount: CEM25P (new)
OTA: Starwave 70 ED Quad APO
Quide: ZWO Mini Guide Scope
Main Camera: ASI294MC Pro
Guide Camera: ASI120MM S
Issue:
I have a problem with guiding the DEC pulse seems to be doing nothing. I've included the log and you can tell when there is a "DECGuideDistance" it is the exact same number as the "DECRawDistance" when over .2 (that part is good). BUT from the results, you can see it has no effect. I also get error code on RA sometimes, but RA is good.
I'm hoping you can see what the problem is. I did notice what looks like backlash on calibration moving South. I have the guide rate set at .75x both on the handset and ASIAir.
Question:
Do you intent to have backlash compensation, minimum move and >100% aggressiveness and as an option on later versions?
Any help is much appreciated.
Michel
