Hi,
the recommended order is: (Adapter) - OAG - 11 mm ring - T2-T2 Adapter - EFW - Camera
Is it possible to mount the OAG closer to the filter wheel?
(Adapter) - 11 mm ring - T2-T2 Adapter - OAG - EFW - Camera
or
(Adapter) - 11 mm ring - OAG - T2-T2 Adapter - EFW - Camera (OAG turned 180 degrees)
The main Camera is a 294 and the guide camera is a 120 Mini.
If I use the 120 without the black front ring, focusing should
be no problem, right?
Thank you!
Markus
