My EAF was working well and Auto Focusing as it should. Two nights ago it started beeping and would not move "In" or "Out." The draw tube was still at the last focus point, so the cause was not because it was at a limit.
Today I took the EAF off of my Focuser and reset everything. It no longer beeps and it is moving "In" and "Out" again. I set the draw tube to the marking on it of 0 and in ZWO EAF Setup I "Set zero" at that point.
My draw tube markings go from 0 to 45; therefore, I set the "Max Step" to 45000. However, when I "Move" to 45000 it beeps and stops at 17181 in the software but physically goes to 45 on the draw tube. Shouldn't the stop and the marking be the same; 45000? If they should, how do I fix this?
Patrick
