Which method would be best and most problem free in terms of compatibility? can I use the EQDirect cable? Will it work with the Atlas?
Both synscan(connected by HC)or Eqmod(directly connect) is ok for Asiair,
With the handset i still have to do 3 star align, correct?
Yes,when trying to connect the air by HC,sometimes need to do 3 star align
Which method would be the suggested one if i have both options?
Both ok. some prefer the HC(to control the mount) some prefer the Eqmod
If i can use the EQDirect cable on the Atlas EQ-G, what do i choose for "mount"? in settings.
=>EQmod
HC => synscan or synscan pro
