Hi,
I recently installed an EAF. The focuser is working fine, but I get random disconnections.
I am using the EAF with NINA. Connect it with ASCOM driver.
Sometimes the EAF disconnects from NINA. I talked to NINA devs and they say it's a driver issue
Driver 1.0.1.8
This is from NINA logs:
Start
D:\Projects\nina\NINA\Utility\DeviceUpdateTimer.cs
IsMoving Failure at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type parameterTypes, Object parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs 288
at ASCOM.DriverAccess.Focuser.get_IsMoving() in C:\ASCOM Build\Export\ASCOM.DriverAccess\Focuser.cs 80
at NINA.ViewModel.Equipment.Focuser.FocuserVM.GetFocuserValues()
at NINA.Utility.DeviceUpdateTimer.<<Start>b__16_0>d.MoveNext()
