>> ASIAIR can do Polar accuracy similar PoleMaster?
30 arc seconds is child's play when you use SharpCap or ASIAIR.
I have been able to get well within 10 arc seconds with ASIAIR. That is the number that is reported by ASIAIR -- I don't know how accurate it really is, since the accuracy depends on factors like atmospheric refraction. Since we can't see the source code of ASIAIR, there is no way to find out how large the potential errors are, except from how long you can track an object without using autoguiding.
(One weakness with the ASIAIR is that the engineering specs like polar alignment accuracy are not available.)
With patience, I have gotten the reported polar alignment error to within 2 arc seconds, but both of my mounts moves 10 seconds or more off when I lock the altitude and azimuth bolts (the RST-135 is especially poor in that regard). That makes trying for more precision rather moot :-). Since I always auto guide and do not do exposures of more than 180 seconds, the field rotation is tolerably small even when the error is as large as 30 arc seconds, so I don't even spend time for to get better than 10 arc seconds anymore. I suspect that when winter arrives, I would settle for even 30 arc seconds, and then scoot indoors to do everything else :-).
The ASIAIR reports the altitude, azimuth, and total error in actual numbers, and not just graphically -- I have found the graphical interface to be rather superfluous, and simply adjust the bolts based on the error numbers.
(I had made a request through a more direct channel for ASIAIR to also report the error as an audible pitch (like on the Hinode Solar Guider), and if they implement that, it should make adjustment in the dark, and with your hands full on the adjustment bolts, an even easier task than adjusting by numbers.)
I have stopped using my PoleMaster when SharpCap implemented plate-solved polar alignment, and I stopped using SharpCap after ZWO included plate solved polar alignment in ASIAIR. Before polar alignment appeared on ASIAIR, SharpCap was worth its price just for the polar alignment function alone, IMHO. And now you have a similar function baked into the cost of the ASIAIR.
Best regards,
