Hi,
I`m using the celestron CGX-L and a smal Ioptron ZEQ25 with the AsiAir and Ipad. The setup with the Ioptron works great. With the Ioptron I have the opportunity for directly control the mount via the app and also to adjust the movement speed. I do not have this option with the CGX-L. If I want to intervene there I have to do that via the hand controller. Is there a solution for the problem?
Using SkySafari Pro and IOptron ZEQ25 the Ioptron responds with a delay of up to 30 or 40 seconds on control commands via SkySafari. Where could the problem be here? Software is up to date everywhere.
Best regards from Germany
Dirk
