hi
when i want to do flat , how to set up the the pics (duratuion? gain must be the same as the light ?)
i get the asiair and the filter wheel, too
mfg stephan kobalt nordstern
Hi,
We recommend you make the flats ADU around 25000 to 30000.
Gain can be set as low as possible.
If you use filter wheel, you need to make flats for every filter.
Thx
What does u think how long should the flat be on losest gain 1sec 0,5 sec?
g Nordstern
Hi g Nordstern,
It depends, as long as it can enable you to get ADU around 25000-30000, you can have some try.
