Hi sir
If you want to change the interface from the default WiFi Port (interface 1) to the Serial Port
(interface 0), do the following:
NOTE: This assumes that you start with the delivered configuration of the PMC-Eight™ with the
WiFi interface enabled.
1. Set your SSID to the PMC-Eight-xx, whichever yours is.
2. Using Putty, TELNET into address 192.168.47.1 port 54372.
3. You should be greeted with the *HELLO* prompt of the RN-131 module.
4. Enter "###", and you should see "Diagnostic Mode Disabled#!”.
5. Enter "ESX!", and you should see "ESX0!", which indicates that the interface was switched
to the serial port (interface 0).
