Your hardware / software works perfectly. I am using the Celestron CGX mount with the Celestron Edge HD CPC1100 OTA and your mini guiding scope with my iPad. So easy to set up... point mount north, use PA (note: when I turn on scope, I just perform a quick align, not 2 star alignment required, works flawlessly), pick an object in your catalog and hit goto, plate solve, then sync and goto that object for alignment. I'm typically imaging inside of 10 minutes. So easy, thank you. I move my scope inside every day and put it back out when I image. So, I've set up and broken down about 10 times now and your program works flawlessly.
My only question - when I fill up the card, I have used the image management to delete files and clear the cache / used space. However, the space never clears. I have to pull the card and reformat to clear the card. Is this an expected feature? It seems that if I delete the files and clear the space, my card should be empty again but it is not.
Thanks,
Rick
