taro@seki.tv wrote:
Hello Ji
Thank you for understanding.
i'm looking forward good news.
Clear sky
How to Use the iEXOS100 with ASIAIR
#1 Switch the controlling interface
Follow the below document to change the interface from the default WiFi Port (interface 1) to the Serial Port (interface 0)
Explore Scientific PMC-Eight® Application Note PMC8-AN003: Switching Between the WiFi Interface and the Serial
#2 Connect to the ASIAIR
1. Power on the ASIAIR & iEXOS-100 (in the Park Position - this is with the scope pointing towards the pole and the counterweight straight down)
2. Connect the iEXOS-100 to ASIAIR via a USB cable (Need to buy separately, refer to the above document Page.3)
3. Open the ASIAIR app, go to the Telescope Settings page, choose in the drop-list then tap the right switch to connect
#3 A screenshot of the ASIAIR app
Note: The Serial: USB-RS232 and the Baud: 115200 should be shown before connecting.
Here I share the pdf file for you: https://astronomy-imaging-camera.com/public/How_to_Use_the_iEXOS100_with_ASIAIR.pdf
I think this would help.
