Hi!
Today I updated ASI to 1.3 (3.37) (on Android). And I got problems.
My setup: SW HEQ5Pro mount with eq-direct cable, ASI 178mm guiding cam, ASI 1600MMC main cam, ZWO EFW.
1. After 5-10 minutes of work tracking stops with error "Abort tracking. Telescope points beyond the horizon":
I tried both modes (EQMod Mount and EQMod with safari) - same error.
Date/time and position settings in phone is correct (Is time on this screen UTC? Real time was: 21):
2. Guiding errors:
Guiding is going well for a while, then app freezes on 3-5 seconds and mount moves along one of the axes (Ra is more often then Dec). Stars in the image are stretched.
But without guiding there are round stars in the images.
On the previous version of the software, everything worked well.
Please fix this issues.
And can you send me previous version of Android ASIAIR apk? Because it is impossible to work on the current version.. :(
