Ji xian sheng,
PHD2 Minimum Move (MinMo) and low pass filter (LPF) parameters are not just for advanced users, but also required by beginners who own mounts that have large periodic errors (PE), but with very long periods.
Because of the long periods (for example, 430.82 seconds for the Rainbow Astro RST-135), the large PE (40 to 50 arc seconds peak-to-peak with the RST-135) is actually correctable, but you either need a very small MinMo value, or guide scopes that have very long focal lengths, together with very short sampling time (guide scope exposure) .
Because of the short sampling time, you also need the PHD2 low pass filter so that when "seeing" becomes poor, you won't be tracking the seeing.
Examples of mounts that exhibit these behavior include mounts that incorporate strain wave gears ("harmonic drive") such as the RainbowAstro RST-135, 150h and the Hobym Crux 170HD. Additionally, the Avalon M-zero (belt drive) also has large PE, but long periods.
This Avalon web page has recommendations of MinMo, exposure, and lowpass mount guide algorithm:
https://www.avalon-instruments.com/13-troubleshooting/117-phd2-guide-suggested-parameters
You can see from the above that Avalon recommends a MinMo of zero (!), while using the Lowpass2 filter, and an exposure time of 0.5 to 1 second.
All that is needed is an Advance Button that allows the user to type in the MnMo value, and be able to select Lowpass2 or Default as the Mount Guide Algorithm. These parameters can then be sent to PHD2.
Best regards,
