Thanks Chad. I worked along your suggestion.
Note that BZERO =0 does not lead to a 0-65535 range, in my case, but to 0-32767, which tells me that ImgBuff is not coded as unsigned but as signed. Hence, setting BZERO to 32768 successfully solves the issue.
Cheers,
Remi
Attached is a working code.
int main(int argc,char **argv)
	void            parse_args(int, char**);
	int width, height;
	int i;
	char c;
	bool bresult;
	fitsfile *fptr;       /* pointer to the FITS file; defined in fitsio.h */
    int fitstatus = 0, ii, jj;
    long fpixel = 1, naxis = 2, nelements, exposure;
    long naxes = {5496, 3672};   /* image is 5496 pixels wide by 3672 rows */
//    long naxes = {1280, 960};   /* image is 1280 pixels wide by 960 rows */
    long bzero, bscale, gain, xbin, ybin;
    float pixsize;
	int time1,time2;
	int count=0;
	int CamNum=0;
	exptime = -1;
         * Read command line arguments
        parse_args(argc, argv);
	int numDevices = ASIGetNumOfConnectedCameras();
	if(numDevices <= 0)
		printf("no camera connected, press any key to exit\n");
		getchar();
		return -1;
	else {
		ASI_CAMERA_INFO ASICameraInfo;
		ASIGetCameraProperty(&ASICameraInfo, 0);
		printf("0 %s\n", ASICameraInfo.Name);
		if(ASIOpenCamera(CamNum) != ASI_SUCCESS)
			printf("OpenCamera error,are you root?,press any key to exit\n");
			getchar();
			return -1;
		ASIInitCamera(CamNum);
		ASI_ERROR_CODE err = ASIEnableDarkSubtract(CamNum, "dark.bmp");
		if(err == ASI_SUCCESS)
			printf("load dark ok\n");
		else
			printf("load dark failed %d\n", err);
//		printf("%s information\n",ASICameraInfo.Name);
		int iMaxWidth, iMaxHeight;
		iMaxWidth = ASICameraInfo.MaxWidth;
		iMaxHeight =  ASICameraInfo.MaxHeight;
//		printf("resolution:%d X %d\n", iMaxWidth, iMaxHeight);
/*		ASI_CONTROL_CAPS ControlCaps;
		int iNumOfCtrl = 0;
		ASIGetNumOfControls(CamNum, &iNumOfCtrl);
		for( i = 0; i < iNumOfCtrl; i++)
			ASIGetControlCaps(CamNum, i, &ControlCaps);
			printf("%s %s %f\n", ControlCaps.Name, ControlCaps.Description,  ControlCaps.DefaultValue);
// ASI183MM Pro
// Gain Gain 0.000000
// Exposure Exposure Time(us) 0.000000
// Offset offset 0.000000
// BandWidth The total data transfer rate percentage 0.000000
// Flip Flip: 0->None 1->Horiz 2->Vert 3->Both 0.000000
// AutoExpMaxGain Auto exposure maximum gain value 0.000000
// AutoExpMaxExpMS Auto exposure maximum exposure value(unit ms) 0.000000
// AutoExpTargetBrightness Auto exposure target brightness value 0.000000
// HardwareBin Is hardware bin2->No 1->Yes 0.000000
// HighSpeedMode Is high speed mode->No 1->Yes 0.000000
// Temperature Sensor temperature(degrees Celsius) 0.000000
// CoolPowerPerc Cooler power percent 0.000000
// TargetTemp Target temperature(cool camera only) 0.000000
// CoolerOn turn on/off cooler(cool camera only) 0.000000
		long ltemp = 0;
		ASI_BOOL bAuto = ASI_FALSE;
        err = ASISetControlValue(CamNum, ASI_GAIN, 50, ASI_FALSE);
        err = ASISetControlValue(CamNum, ASI_TARGET_TEMP, -1, ASI_FALSE);
		err = ASISetControlValue(CamNum, ASI_COOLER_ON, 1, ASI_TRUE);
		err = ASIGetControlValue(CamNum, ASI_TEMPERATURE, <emp, &bAuto);
		printf("sensor temperature:%02f\n", (float)ltemp/10.0);
                while (ltemp > -1) {
			usleep(30000000);
// Set image caracteristics: width, height, binning, type (ASI_IMG_RAW8 or ASI_IMG_RAW16)
// default values are CCD size 5496x3672, binning 1, TYPE 16.
		width = iMaxWidth;
		height = iMaxHeight;
		printf("width=%d height=%d\n",iMaxWidth,iMaxHeight);
	    int bin = 1;
   ASI_IMG_TYPE Image_type = ASI_IMG_RAW16;
		err = ASISetROIFormat(CamNum, width, height, bin, Image_type);
		if (err == ASI_SUCCESS)
		printf("Set ROI ok: width %d height %d bin %d Image_type %d\n",
				width, height, bin,Image_type);
	else
		printf("Set ROI failed %d\n", err);
		usleep(10000);//10ms
		long imgSize = width*height*(1+(Image_type==ASI_IMG_RAW16));
		unsigned char* imgBuf = new unsigned char;
		//ASISetControlValue(CamNum, ASI_GAIN, 0, ASI_FALSE);
		int exp_ms; 		// input exposure time(ms)
		if (exptime<0)
			exp_ms = 10000;
		else
			exp_ms = 1000*exptime;
	ASISetControlValue(CamNum, ASI_EXPOSURE, exp_ms*1000, ASI_FALSE);
	ASISetControlValue(CamNum, ASI_BANDWIDTHOVERLOAD, 40, ASI_FALSE);
	time1 = GetTickCount();
	ASI_EXPOSURE_STATUS status;
	int iDropped = 0;
	//bool bSave = true;
	ASIStartExposure(CamNum, ASI_FALSE);
	usleep(1000000);//1000ms
	status = ASI_EXP_WORKING;
	while(status == ASI_EXP_WORKING)
		ASIGetExpStatus(CamNum, &status);
	if(status == ASI_EXP_SUCCESS)
		ASIGetDataAfterExp(CamNum, imgBuf, imgSize);
		printf("imgBuf ");
		for (i=0;i<20;i+=2) {
			printf(" %d ", 256*imgBuf+imgBuf);
//		printf("\n");
		time2 = GetTickCount();
		count++;
		if(time2-time1 > 1000 )
			ASIGetDroppedFrames(CamNum, &iDropped);
			count = 0;
			time1=GetTickCount();
			printf("fps:%d dropped frames:%d ImageType:%d\n",count, iDropped, Image_type);
// Save a fits image in a folder of the night and time
		istimeto();
		sprintf(commande,"/bin/mkdir -p ./TBLAstrometry/data/%s", nuit);
    		system(commande);
		sprintf(fitsname,"./TBLAstrometry/data/%s/%s",nuit,image_name);
//		fits_create_img(fitsfile *fptr, int bitpix, int naxis, long *naxes, int *fitstatus)
//		fits_write_pix(fitsfile *fptr, int datatype, long *fpixel, long nelements,
//						void *array, int *fitstatus);
		bzero = 32768;
        bscale = 1;
        gain = 50;
        bin = 1;
        pixsize = 2.4*bin;
		fits_create_file(&fptr, fitsname, &fitstatus);
		fits_create_img(fptr, SHORT_IMG, naxis, naxes, &fitstatus); // SHORT_IMG = 16
		exposure = exptime*1000;
		fits_update_key(fptr, TLONG, "EXPOSURE", &exposure, "Total Exposure Time ", &fitstatus);
        fits_update_key(fptr, TLONG, "BZERO", &bzero, "physical = BZERO + BSCALE*array_value", &fitstatus);
        fits_update_key(fptr, TLONG, "BSCALE", &bscale, "physical = BZERO + BSCALE*array_value", &fitstatus);
        fits_update_key(fptr, TLONG, "GAIN", &gain, "The ratio of output / input", &fitstatus);
        fits_update_key(fptr, TLONG, "XBIN", &xbin, "Binning factor in width", &fitstatus);
        fits_update_key(fptr, TLONG, "YBIN", &ybin, "Binning factor in height", &fitstatus);
        fits_update_key(fptr, TFLOAT, "XPIXSZ", &pixsize, "Pixel Width in um (after binning)", &fitstatus);
        fits_update_key(fptr, TFLOAT, "YPIXSZ", &pixsize, "Pixel height in um (after binning)", &fitstatus);
		nelements = naxes * naxes;          /* number of pixels to write */
        fits_write_img(fptr, TUSHORT, fpixel, nelements, &imgBuf, &fitstatus);
		fits_close_file(fptr, &fitstatus);            /* close the file */
		fits_report_error(stderr, fitstatus);
	ASIStopExposure(CamNum);
	ASICloseCamera(CamNum);
	if(imgBuf)
		delete imgBuf;
	printf("main function over\n");
	return 1;
