Dear Sirs,
I use the ASIAIR on a Skywatcher EQ8.
To achieve a reduction in cable, I have purchased the Skywatcher Wifi dommel.
Given that this is more accurate than the traditional Synscan handset.
Given that you have a possible connection between the Synscan WIFI and ASIAIR on the internet.
Given that in the example you connect the AZ-GTI Mount of Skywatcher with the ASIAIR.
It may be that the connection in combination with the EQ8 with Skywatcher WIFI must have a different setting in the Skywatcher AP.
To date I have not succeeded in describing you as seen on the internet.
(HOW to use ASIAIR with Skywacher AZ-GTI Mount).
With best regards,
J.J.Dekker
