>> Is anyone else with this mount having issues with the ASIair latest update to version 1.3? I'm running the iOS version on an iPad.
Hi Mel,
First of all, check the time zone using the RST-135 Hubo-i hand controller. RainbowAstro's concept of time zone is messed up -- depending on the firmware version, it does not understand daylight savings time, although that shouldn't bother you in Arizona.
To exacerbate the problem, ASIAIR has no ability to read the time zone back from the mount (confirmed with ASIAIR QA), and the ASIAIR reports your time zone as being on the Greenwich meridian. A good check is to obtain a GPS lock on the hand controller, apply a long press of the ENT button to transfer the GPS time to the mount's "working" time, and then launch ASIAIR to see what it reports as the mount's local time - it should be the same as what your watch tells you.
A Sync To Mount (from a couple of iPad and iPod Touch models) does not appear to hurt the time zone setting, at least on iOS. But the displayed information is incorrect (I had suggested to ZWO that they at least report it as "Not available" instead of as "GMT.")
Check the telescope settings window and make sure the other fields (Latitude, Longitude and Local Time) are correct. If not, the date/time/time zone are the usual suspects when it comes to pointing errors. (Meridian flips were a nightmare until I found that the RST-135 does not grok time zones -- Korea does not have Daylight Savings time :-).
FWIW, I have only used the ASIAIR v1.3 *beta* in night skies. Our Oregon skies are not as forgiving as Arizona at this time of the year, sans your monsoon season (I stayed in Phoenix for a couple of years :-), so I have not been able to use the released ASIAIR v1.3 under night skies yet. However, when I used the object database in the released version of ASIAIR indoors, the RST-135 seems to point in the correct general direction.
In fact, ASIAIR 1.3 beta had been quite reliable that I no longer even take the Hubo-i hand controller out (one fewer item to carry, connect and tear down :-). I only use the hand controller now to set defaults and it goes back into the shipping box.
Be sure that you have updated the mount's firmware. The most recent one from RainbowAstro is V.190905 from back in the beginning of September.
Oh, another quirk with ASIAIR and the RST-135 ever since v1.3 beta. ASIAIR no longer complies with the four slew speeds that you have set up as defaults by the hand controller. Instead, ASIAIR now uses the 1x, 2x, 4x,... 256x, 512x and MAX (I guess so that the app itself is uniform across different mounts), but messing up the experience of RST-135 users.
Instead of the four speeds (which on ASIAIR v1.2 appeared as guide, fine, center and max), ASIAIR now uses Speed 2 (as seen on the hand controller) as its universal mount speed. So, Speed 2 is left at whatever speed was most recently used by ASIAIR. If you had set up Speed 2 as 100x as for manual use, you will need to re-apply the Speed 2 default to 100x again after using the ASIAIR (pain in the royal **** :-).
One more ASIAIR quirk: the Home button in the ASIAIR telescope settings window does work, but does not warn you that it has not yet reached home, in the case you started more than 90 degrees away from home (the 90 degree is the fail safe limit on the mount). So, if you apply the home key from indoors, you may want to do it a second time (blindly) after the first home operation finishes. (The home position is the safest position for the RST-135 when it comes to the backdrive problem of the harmonic drives, especially if the mount is in semi-balance in declination.)
After two local modifications, the RST-135 and ASIAIR make a really nice lightweight solution for me (I used to use a much heavier "lightweight" Takahashi EM-11.)
Cheers from the Pacific Northwest rainforest,
