Hello,
I plan to support ASI cameras in a commercial application where the licenses are bound to a unique camera ID.
For that to work i need to be able to access some kind of "unique enough" information, that can not be modified.
An actual serial number would be perfect, but a combination of other values would also be ok.
For my application the ASI174 ist probably the best choice.
What options do i have to get a unique id from that camera?
If there is no default data, might there be a unique and reproducible pattern in the sensor data that i could use?
Best regards,
CarpeBoth
