HI - I hope things are all going well given the Corona virus outbreak.
Tthank you for the X2 driver. Since this is now available from TSX, I installed an EAF on my scope last week. All works well except for reporting the temperature.
This is only available from within the settings section of the interface. However, the temperature is not then available within TSX which means that e.g. scripts which monitor the focuser temperature do not work.
Reporting the temperature to TSX is pretty straightforward - you just need to implement the focuser temperature interface - see below.
https://www.bisque.com/x2standard/class_focuser_temperature_interface.html
Would you be able to add this into the next release?
Thank you,
Colin
