Sometimes, ASI1600MM Pro image download hangs in SGPro. The only workaround is to close and re-open SGPro.
Also, I use ASI1200MM as guide camera. In PHD2, the image can shift about half frame or flip. It happens nearly once every hour. I stopped the loop and then re-loop, then the image would be back to normal.
I have updated the driver to the latest version.
