Hi there, I have been using an ASI224MC for a few months now to image the planets and it’s working really well, thank you for developing this product. One thing I’ve noticed while imaging is that I need to make significant changes to the colour balance after capturing and stacking the frames, in particular the raw images come out too green. I am using FireCapture to take the images and use the recommended white balance settings of Wred=52 and Wblue =95, but I always need to increase the blue and red levels and decrease the green level in order to make the final images “correct”.
You can see the effect in my posting on the Cloudy Nights website below for examples.
https://www.cloudynights.com/topic/685348-colour-correction-settings-for-asi224mc/
Christophe Pellier recommends setting the Wblue value to 99 (the maximum) and even then it’s not high enough.
https://www.planetary-astronomy-and-imaging.com/wp-content/uploads/2019/02/Planetary-imaging-with-a-colour-camera.pdf
I spoke with Torsten who writes the FireCapture program and he is unable to program a Wblue value higher than 99 since the ZWO SDK does not allow for values greater than 99. So to get to the point (finally);
Can you please create a new SDK file for the ZWO cameras where the maximum Wred and Wblue values are (say) 150?
This way I can set a better white balance for the camera straight out of the box, without having to rely on modifying the colour settings after capturing.
Thanks for your consideration in this matter.
Andrew
