Hi there!
Is it possible to integrate the ASI Air in my own WiFi network? Means: Can I edit the IP adress to use the software in my network? If yes, howdo?
THX!
Jens
Jens_M wrote: Hi there! Is it possible to integrate the ASI Air in my own WiFi network? Means: Can I edit the IP adress to use the software in my network? If yes, howdo? THX! Jens
Hello Jens, this is the main change in the next version v1.4 which will be released recently.
