je2000 wrote:For whatever reason this app keeps swapping E and W on my AZ-EQ5. I set everything up in the controller, 97 W, 39 N. These coordinates always load wrong in the app, so I have to press Sync to get it to see W. Negative. West of the meridian. Swapping back and forth from Skywatcher Pro, trying to get a plate solve. No luck, so I slew to another target. Nothing seems right so I look out to discover the scope pointed down at the ground, wrapped to hell in wires. Skywatcher Pro is showing on correct target. I hadn't even moved that far over from E to W so I wouldn't have expected the scope to do a complete 180 from where the target was, pointing opposite to the ground.
Now only one axis will slew. The other gets nothing either from hand controller or app. I fear the gears or something are terribly wrong. The mount will only slew on one axis. If someone can point me to a tutorial on how to check this mount for damage that would be much appreciated.
What is the deal with this bug? The device and app are unusable if it's constantly reversing it's position on Earth. Why is longitude constantly switching E and W? Do you need to constantly sync this manually? Are you not able to switch back and forth between Skywatcher Pro? If I have to constantly stand by the scope to monitor it if the longitude is reversing then the device and app are useless to me. The whole point is remote control.
Hello Sir,
This E/W switching issue has been reported by a few users but we still can't reproduce it, now we are going to focus on it again, hope to find out and fix it. Thank you.
Since you are using AZ-EQ5, are you with the EQMod way? If not, please try EQMod.
