For cameras with CMOS sensors, it is best to capture dark frames that are matched to the light frames (same gain, offset AND exposure time). In this case you will not need to scale the MasterDark (that means: the MasterDark will not be calibrated with the MasterBias).
However, the flat frames have to be calibrated, either with a MasterBias or with a MasterFlatDark.
So the short answer is: if you capture flat darks (and prepare a MasterFlatDark), you don't need a MasterBias at all. (The effort for preparing a MasterFlatDark is essentially the same as for preparing a MasterBias.)
Bernd
