Hi I have acquired an EAF for Christmas. I have a a guide cam and mono cam with a filter wheel and mount 4 USB connections. Both cameras don't have additional USB connections. : How can i connect the EAF. I need 5 USB connections
Maybe you can add a USB hub?
Fitted a USB hub yesterday and now all things are running well. Needed to keep the mount directly into the ASIAIR. :)
Great!
I too needed 5 usb ports into my ASIair. I found plugging the filter wheel into the camera hub worked just fine.
Yes, that is also a solution.
