Hello,
First time guiding.
Using ASI 178 on your 60mm guide scope FL 287mm;
to guide a Celestron C8 at f10 2032mm FL
Managed to keep Total Error just under 1", so I was pretty happy for a first try.
300 second exp yielded nice results.
What is Calibration Step, and Max RA (DEC) Duration?
Should I just leave the default? Are there recommended settings?
What is the calibration flip option for? I'm guessing Meridian flip after cal?
The manual is rather thin on guiding for a first time user. Can you recommend something where I can pick up a little more detail?
Thanks
