Hi chuckwagon, thank you for your info.
My mount is a Mountain Instruments MI-250.
I was not guiding, The stars (not including the double issue) were pretty round, so it tracked well.
I will need to test different exposure lengths, to see if the issue gets worse or better.
I will also recheck the balance, and the worm to spur gear tightness, for either backlash or it being to tight.
Since it just started happening recently, I will try to think of any changes I made, besides installing the new powered USB hub.
Fivel
