Hi,
Hope somebody can help. I have been trying to connect my ASIAIR to my new CEM40EC mount without success. I have been using ASIAIR with HEQ5 fine for a while now.
I have tried all suggestions in the forum including:
I) Making sure baud rage is 115200.
II) Seder firmware on SD to original image and then try connecting to mount.
Every time I get an error. Indeed To make sure system is wired correctly I pull the USB out of the ASIAIR and plug into my laptop and Commander works immediately.
The only thing I have noticed is that my mount is running firmware version 190422. Most of the comments here and on other sites seem to assume version 190220. Furthermore when I look on iOptron website it seems to suggest latest firmware is 190220. Could it be this that is causing the problem?
I would welcome suggestions.
Thanks
