I have two android tablets, and have used both with asiair as recently as last month.
I updated both to 1.4
One tablet works, the other will not connect.
Settings - wifi- shows connected.
ASiair connection page says no connection. The only active buttons are scan, which results in the same results, and enter IP. I entered 10.0.0.1 and still no connection.
The other tablet updated firmware and runs fine.
The problem tablet never updated firmware.
Do you have any ideas for what I'm doing wrong/what I should check? The problem is clearly not the asiair, as it works with the other tablet.
