I use my ASI air on a small iOptron Smart EQ Pro + mount.
After doing the recent update to 1.4 it seems to be corrupting the guide settings in my mount.
I have them at the default of 0.5 x Sidereal and it works fine using PHD2 this way.
When I connect the ASIAir to the mount and use the iPad to update location and time and write it to the mount the RA Guide setting changes to 0.05 x Sidereal.
I only noticed this due to the Calibration repeatedly failing and stating the Mount did not move enough during RA calibration.
This is repeatable. If I reset the mount manually to 0.5 x Sidereal and try again the ASIAir changes it to 0.05.
Any suggestions? I can make a video of this if it helps.
Thanks.
