Thanks for the replay:) ,
can pls explain ! If the max current is 12v 6amp input , were ZwO find the way to get 4 x12v 2,5amp out put with only power supply of 12v 6amp , ??
If I have a power supply of 12v 15amp and connect to asiair , the power supply will only will give 6amp to asiair because asiair will only need 6amp to work,!
if I have 30amp or 50 amp power supply will be the same asiair will only consume 6amp , Exemple: water cup with 10 liters and another with 5liters and do a small hole with the same side on each cup , will flow the same quantity of water in both cups does not matter the cup size ( 5 , 10, 30 liters (amp) , does not make sense 6amp max !?!? Or I don’t understand nothing I Lear about amps, watts, voltage in school :)
Another exemple : a lamp with 100 watts will produce the same light connect on 220v 16amp or connect on 220v 32amp ,
asiair outputs 4 x12v 2,5amp are not real?
Mount need 12v 3 amps
ZwO cooling câmera need 3amp
Dew heat 12v 2,5amp
Dew heat for guide scope 12v 2,5amp
Asiair need 3 amps
It’s 14 amps in total ,
Asiair can covert a 12v 6amp in 12v 14amp output total?!?!
Regards John
