Hi!
I am having trouble connecting my ASIair to my HEQ5 mount using EQdir cables. Tried two different brands (PagasusAstro and Lynx) with no luck. Made sure its connected properly on both ends (USB into ASIair and the other end into handcontroller port) and that the mount is powered properly. In the software I have chosen ”EQmod with SkySafari”. All that happens is a popup that says to make sure everything is connected properly and powered on, and that the baud is correct but this is something that I cant change at this stage? The mount is 10 years old, can that be a problem? Is it to old?
My gear:
ASIair (original)
SkyWatcher HEQ5 Pro
PegasusAstro and Lynx EQdir cable
Powered by a Celestron Li Powertank through a PegasusAstro Pocket Powerbox
I would be very glad if someone can resolve what I am doing wrong!
Thanks in advance!
/Tobias
